Old 26-May-2017, 1:30 PM   #2
JoeAZ
Greetings!
I would suggest you keep things simple, especially at first. Most of
your stations come out of the Atlanta market. I would aim for those
stations using a Winegard 7694p antenna using RG6. That antenna
is available at either Walmart or Home Depot .com for less than
$50.00 including shipping. Run that cable to ONE tuner and see what
you get. Be sure to keep your cable run as short as possible. Runs
over 50 feet cause problems you'll want to avoid. Later, you can
add other tuners or perhaps another antenna pointed toward the
multiple transmitters to your Northnorthwest.
