Somethng like that would have been my first recommendation. If you're not willing to use a small outdoor antenna, then the Terk HDTVi would be the next model to explore (it's the non-amplified version.)
Something else to consider - you may be getting overloaded by WPRS 104.1, although that is normally a problem for VHF stations like WJLA and WUSA. Adding an FM trap May help.
You should also post the URL for your TVFool report instead of just giving us a picture. When you do so, please use your exact address to run the report (it won't show.)
