Old 30-Jan-2011, 8:35 PM   #5
scott784
I've got a Monster Power Home Theatre system surge protector, HTS 1000. I was not considering using this as an alternate to proper grounding outside. However, I only brought it up because of the fact that I noticed signal degradation when I ran my coax through it. I was only for that reason that I started to think about any and/or all intermediary devices causing signal loss when you run those devices between the coax up at the antenna and the final point where the coax meets the television. Thanks.
scott784 is offline   Reply With Quote
