Thread: Rca ant751
Old 24-May-2017, 7:12 PM   #56
Wondering what kind of polarization did you use?
Everything (TX & RX antennas) was horizontally polarized since that is the de-facto standard for North American TV broadcasting as well as the design of all of the tested antennas. I could just as readily, with a bit of hardware modification, have rotated everything 90° but it would have had little to no impact on the recorded results except possibly for ground reflection influence.
How much of a factor would the polarization play in your tests??
Not sure what detail you're inquiring about, but I can say that from prior experience, that if I cross-polarize one of the antennas, there's usually a penalty of 20 dB or more.
