Thank you for the reply
You are correct that most of the stations come in fine. It is the one that is at ~90 degrees that is choppy and occasionally drops out.
Thank you for that explanation. It makes sense. Looks like I'll need to figure out a different way to get the Fox network. The house had previously been wired for cable TV, so I might just run the second antenna to a different room.
