Thread: Picture quality
Old 21-May-2017, 5:49 PM   #3
harold
There are on trees or other obstructions between me and the tower at 296, or 349. I have no problem with the south east 134. KAUZ and KSWO are the only channels I'm trying to receive from that direction. Actually the only channel I need in that direction is KSWO. I get a live stream by internet for KAUZ. Just can't record on TIVO. The cables I'm using were made for me by the local cable company. On the cover says, series 6 CATV.
I read somewhere that with two antenna they should be at least three feet apart, and should be connected with equal length cables. That is how I know the length of all my cables. K34JJ and K35KE problem I've heard is the OKC channels cut power. I also thought FCC wouldn't allow two channels be as close together as the K18IZ, K18HX are. They are less then 70 miles apart.
I'm thinking my best option will be to set the two at 296, and 349. forget trying KAUZ. maybe add a vhf for KSWO.
harold is offline   Reply With Quote
