Old 20-May-2017, 7:25 PM   #7
ota north-south
Thanks for the replies.
All the Wally's around here have the C2max in stock, but not the C2V.
I also saw 95% 5 star reviews for the C2v. Not a lot of reviews on the C2max,
but that's probably because it's pretty new.
My Dish is still on the roof, I was going to remove the dish and install the antenna there as the cable is already there. I'll check the line of sight when I get up on the roof.
The Dish installer used a dual RG6 and both run to a grounding block in the garage, where it's grounded to the outdoor water faucet in the garage. One of the RG6 cables ends at the grounding block and the other RG6 cable goes from the grounding block thru the wall to the TV. I have to wonder why he used dual RG6 cable?
I'll report back once I get up on the roof and check out the line of sight.
Joe, you are correct. Most of the channels come out of Denver.
Cheyenne does have 6 good channels. 5.1,5.2,5.3,27.1,27.2,27.3 and I would like to get those channels clearly. The trees are an issue, so before I do anything I'm going to check out the line of sight on the roof.
Got some snow on the roof right now from our spring storm, but it's warming up so the snow will be gone soon.
ota north-south is offline   Reply With Quote
