Thread: Picture quality
Old 19-May-2017, 11:19 PM   #1
harold
Picture quality
* I have a two antenna setup. Both are antenna direct HDB91X. One is pointed at 300 degrees, the other is pointed 130. The top one is pointed at 130 and is approximately 30 feet. The other is at 26 feet. Both have 3 foot cable into combiner, with 16 inch from combiner to channel master 7777. A 34 foot cable from booster to power in attic, three foot to spliter and two fifteen foot cables to two TV's.
I believe my setup is good. The problem I have is most of the time all channels I'm trying to get come in great. I have a TIVO and when I set to record some times instead of recording with K32IC it will try from another KJTL or K20JB. I also get interference from K18IZ and cant pick up K18HX.
On windy days I lose picture on K34JJ and K35 KE. Not both at the same time and the signal strength for TIVO will show in the 60's without a pictures.
Any suggestions will be appreciated.
Here is the link for my location.
http://www.tvfool.com/?option=com_wr...e6a4ffb1ad0383
harold is offline   Reply With Quote
