Old 30-Jan-2011, 8:09 PM   #4
An RCA ANT-751 is a small outdoor antenna that is actually 'more' antenna than absolutely necessary, but would provide excellent reception for you. If you have no significant amount of metal in the construction of your home, a simple and inexpensive set of rabbit ears would offer very good reception also. As John has already said, you do not need any amplifier, in fact it is likely being overloaded and causing the problems with your reception.
