Old 9-May-2017, 6:45 PM   #32
Bigbear
Thanks, I'm getting a little lost in the technology. I understand analytical chemistry instruments, but your world is foreign to me.
I have one local VHF channel that I currently can get ( quite well via the back side of my antenna). In looking at my signal analysis chart I notice that CTV channel 6 from Montreal is not shown. It comes in quite well with my current set up.
So this proposed setup using an un powered UHF antenna pointed at 111 degrees true azimuth will work.
The remaining confusion is regarding the power pass diagram for the signal combiner. It indicates the power will not be shunted to my existing antenna, correct? My assumption is that my existing antenna will be connected to the VHF input of the combiner. Am I way off base?
Thanks for your patience.
Bear
Bigbear is offline   Reply With Quote
