Old 9-May-2017, 2:18 PM   #31
was lead to believe that the Antenna Direct would not pass power to my antenna pre amp.
Please re-read my previous statements, they address this question.
I think I was told to mount the UHF antenna pointer to my local channels and run a separate cable into the house and combine the cables "down stream" of the amps power tap. Is this not correct
That will work PROVIDED your existing VHF antenna also picks up the local VHF channel, even when aimed at Montreal. If it does not, then that station will be lost unless extraordinary measures are taken (custom components).
