Old 9-May-2017, 1:44 PM   #30
Bigbear
Thanks
I was looking for a smaller one to mount in the basement. I was lead to believe that the Antenna Direct would not pass power to my antenna pre amp.
I think I was told to mount the UHF antenna pointer to my local channels and run a separate cable into the house and combine the cables "down stream" of the amps power tap. Is this not correct?
Thanks
Bear
Bigbear is offline   Reply With Quote
