Old 4-May-2017, 3:16 PM   #1
Bigbear
One channel from same location pixelating
http://www.tvfool.com/?option=com_wr...e6a403c11d2bb9
I got a new TIVO Roamio DVR and I'm having issue with WCAX-tv. It pixelates
while the other channels from the same direction do not.
I have an old antenna that came with the house. I have a pre amp on the antenna. I use 75 ohm cabling and a 4 channel in house amp as well. The cable to the TIVO also goes through a Monster power bar.
So far I have swapped the cable from the power bar to the TIVO, and switched the cable to the power bar.
So far nothing has helped. BTW with all the same cabling when using my old HD TIVO I did not have this issue.
Any ideas?
Thanks
Bear
Bigbear is offline   Reply With Quote
