Replaced the coax. Problem solved at least in terms of getting reception again. Using the U4000 but have lost some signal on Ch. 26. Now borderline quality with a SNR of around 15. Previously it was around 20 to 22 SNR. Ch. 50 and 51 are right around 20 db SNR with this antenna just like previously when coupled with the Titan pre amp. Ch. 22 is fine.
Now I just have to find a suitable replacement for the DAT 790 MIX. That worked well here and I had virtually no multi path break up. That is a major issue at this location.
Wondering if the MCM Electronics clone of this antenna minus the pre amp would work as well as the DAT 790 if I used the Titan pre amp?
