I'd try a 4 bay with the reflector removed, aimed at 195 true and a separate VHF aimed at 0 degrees, combine with a combiner, (or a pre-amp with separate VHF/UHF inputs).
With the reflector removed and the approximate 60 degree beam width you'd have a good shot at getting most of the major networks between the northern and southern towers.
But,,,, the trees are the big unknown. You may be able to find a sweet spot to put the antenna, maybe not.
