Although the Clearstream 5 is a nice antenna, I have little use for the broad beam and UHF gain.
The UHF is going to get stripped of by the UVSJ anyway so it's a non-issue. To achieve narrow beamwidth requires a lot of metal up in the air, generally an array of elements that cause it to have a more focused reception pattern. Typically, that means more real estate that the antenna's elements must occupy in some dimension.
I would like to see some specs on frequency response and gain of a VHF/UHF diplexer, but that may be wishful thinking.
See post #7 in this thread from last week. I just happened to have provided that data.
http://forum.tvfool.com/showthread.php?t=16265
