Old 30-Jan-2011, 1:11 PM   #8
No static at all
No static at all's Avatar
Originally Posted by EMNY View Post
The ANT751 at less than half the size of the 7694P is more manageable. Splitting the signal for only 2 TVs, would I be able to get pretty comparable performance out of the 751 as to the 7694P, or would there be too much signal degradation? Would I need to take extra measures to get the ANT751 to perform reasonably?
The ANT-751 should work fine for 2 TV's, but 3 may be a stretch. If you ever decide to add more TV's & find reception to be un-reliable, a quality distribution amp(~$30.00) may be added to preserve signal strength to all outlets.
The only possible concern I have is WPGC-FM which may cause issues with one channel. If channel 9 proves to be a problem, it is a cheap,easy fix.(FM trap ~$10.00)
