Old 13-Apr-2017, 7:26 PM   #12
kenh999
I took the Winegard Flatwave to the roof and taped it to the same stepstool used yesterday for the 1ByOne antenna. Connected it via splitter (had no barrel connector) to the same coax as yesterday. I tested it with and without the amp in both locations.
Two conclusions and a new issue:
1. The flatwave performed better than the 1byone antenna.
2. The new location with a more open path on 97-99 degree heading is preferable.
3. No idea why I lost Ch. 7.
For comparision purposes below is a table with the SNR values for today's test added, with the understanding that SNR values are not the same as signal values alone.
So, your recommendations??
Different/higher gain antenna?
Better Preamp?
kenh999 is offline   Reply With Quote
