Old 12-Apr-2017, 8:53 PM   #8
kenh999
That sounds like an excellent plan, let us know how it works out.
I did see that comment in the Amazon review section and I can pretty much guarantee it's bass-ackwards based on what I do see unless they stuffed an amplifier on the front of the antenna inside that nosecap. If that cap can be popped off without damage, a photo there would be instructive. If you have a chance, can you provide photos of the area of the antenna where the coax attaches and one or more photos of the indoor module? Just curious as their seems to be no documentation on the seller's website.
VERY Disappointing results. Before I get into that, you are correct about the amp.
Pulled nosecap off and here's what is there
Other end w/coax connection
Signal reception is much worse. Totally surprised me. Using a new 50' RG-6 and only get TWO channels, 24 and 7. Tried adding some elevation above trees in distance to no avail. Here's 2 pics to give an idea of what I did.
second try w/more up angle
first try
I'm close to being pissed. I get better reception with the indoor Winegard non-amp flatwave. Geez. Even the original location through trees is better.
Damn
kenh999 is offline   Reply With Quote
