Old 8-Apr-2017, 2:30 AM   #6
JoeAZ
Jeff,
Another possibility would be to run two of the lower loss RG6
cables from your antennas to the tv set, making sure the run is no
more than 50 feet. You could continue to use the current antenna,
pointed exactly as it is. A second antenna, possibly a Winegard
7698p, aimed at the cape, with it's own RG6 run to the set. You
then would use a low loss A/B switch to provide the proper antenna
for the correct stations. I've installed lots of antennas over the
years and have found that to be one of the best options to maximize your signals..... It is not as convenient as a combiner but you are more likely to get better results, overall. Let us know how you end up...........
