Old 7-Apr-2017, 10:03 PM   #4
jcn3604
Thanks for the quick response, guys.
First, sorry I didn't say, but there is only one TV.
Sounds like the first thing to try is to bail on the RG59 that is in the walls. The antenna is on the back of the house and the TV on the front. I think if I run some RG6 over the roof and down to the TV, I can get to the set with under 50', maybe under 40'.
Unfortunately the trees are close to the house and mostly between the antenna and the Cape Girardeau stations, Rf 12 and Rf 22. Nothing to be done about that.
We watch mostly PBS Rf 41, so any direction shift that would lose that channel is a non-starter.
After changing out to RG6 and seeing how that works, do you think it might be worth considering a DB8e to point one panel at PBS (Rf 41) and the other panel at the Cape stations (Rf 12 and Rf 22)?
Thanks again for the input.
Jeff
jcn3604 is offline   Reply With Quote
