Some more update.
I disconnect of UHF antenna to make similar to ClearStream 2V as Jake suggested. Looks like reception is improved for KPIX and PBS. Not confirmed yet as I will have to observe for some more time. for ABC is still not working. ABC is in fact using channel 35 ( confirmed using the physical channel number in the TV )as ADTech mentioned.
The only issue seems to be the reception of ABC channel and I understand there is easy solution for this at this moment.
