Your signals are already strong, so I'm not sure why you would need an amplifier.
What direction is your antenna aimed?
What does you antenna "see" when it looks in the direction its pointed? Buildings? Trees? How far away are they?
I would not have used an antenna like the ClearStream 4V for that plot. It has a narrow beamwidth. An antenna like the ClearStream 1V or 2V aimed north would likely have gotten you the channels at 11 degrees and 306 degrees. If your antenna is pointed north-ish and there is nothing in the way to block signal I would experiment by removing the amplifier and disconnecting one of the two UHF antennas and pointing it north to see what you get.
