Old 27-Mar-2017, 3:05 PM   #12
rickbb
Sure it will, as long as there are no fatal path impairments that block the terminal signal path to the antenna. I do it all the time with a pretty high level of reliability. It does take work and sometimes some luck.
Yep, I get one more than 80% of the time from 85 miles away with a homemade DB4. It's funny how weather affects it, even a strong wind will knock it out.
I get some 60 milers 99% of the time. On the other hand I have some only 30 miles that are darn hard to get, due to trees and a high tension power line directly in the path.
