You're in a unique location... Only two of the available signals are broadcast on UHF frequencies. The Lava, when or if it ever works, is not designed to receive the VHF signals that you have in your area.
Successful reception in your situation will depend on getting a full sized All-Channel antenna mounted above the trees. I suspect you'll need more than a 30' tower to do that. Also, the signals come from many directions, so you would need to weigh the pros and cons of a rotator or multiple antennas.
