Old 22-Mar-2017, 3:04 AM   #17
It might help, but without knowing the exact coordinates of your antenna, it is hard to say.
You can use the interactive map and enter different heights below the map.
Keep in mind that the wave front of 2Edge signals is not uniform because of scattering. IOW, there can be hot and cold spots as you change height.
