Antenna grounding
Hello,
I am helping my in-laws install an antenna and I have a question about grounding the mast of the antenna. The antenna is mounted on a 1.5" pipe buried 4 feet in the ground. I purchased a coax grounding block for the cable. Do I need to ground the antenna mast itself? If i do need to ground the antenna, what are your recommendations?
Thanks
-Nick
