Old 14-Mar-2017, 1:57 PM   #4
The switch is "not" on the same circuit as the TV's power and is "not" on the same circuit as the signal booster's power.....The coax is run separate from all romex in the attic.
Interference can be radiated through the air or conducted through the power wiring, or both.
And, every lite in the is LED.
Every lite in the WHAT is LED?
If you have more than one LED lite, then unscrewing only one might not stop the interference.
Other people who have had this problem have had to try another brand of LED lite to solve the problem.
case history:
Having trouble receiving VHF signals.
http://forum.tvfool.com/showthread.php?t=16058
It was the dimmer AND the LED lights.
