Areas north of Hwy 210 in San Bernadino will find reliable reception from Mt Wilson to be somewhere between very, very challenging and simply impossible as the San Gabriel mountains are in the way.
The only viable strategy is to go big, go tall, and do not attempt to cut any corners or make and mistakes. Even if you do everything perfectly, your results may not be as expected.
Do you want to continue under those conditions?
