Old 2-Mar-2017, 7:07 PM   #3
Welcome, rekop123
rickbb is correct, it's a tough location. I doubt that you will be able to get all the networks you want, but you might get some of them.
The problem is that they are weak and in different directions.
You can have several antennas aimed in different directions, or one antenna with a rotator.
Your best chances, in descending order, are for
KMPH Fox
http://www.rabbitears.info/market.ph...&callsign=kmph
KVPT PBS
http://www.rabbitears.info/market.ph...&callsign=kvpt
KERO ABC
http://www.rabbitears.info/market.ph...&callsign=kero
KBAK CBS
http://www.rabbitears.info/market.ph...&callsign=kbak
KSEE NBC will be the most difficult. At 74.5 miles away, the curvature of the earth will interfere with the signal
http://www.rabbitears.info/market.ph...&callsign=ksee
http://www.tvfool.com/?option=com_wr...ALLTV%26n%3d15
The last hill on the path near Zante causes the most harm to the KSEE signal.
