Old 28-Feb-2017, 11:46 PM   #11
I think I have found the source of interference to WLOS, real channel 13. It is from WYRD FM, which is very close to your location. I don't have your exact address, but this is the FM Fool report I did from an estimate of your location (report also in attachment):
http://www.fmfool.com/modeling/tmp/e...9/Radar-FM.png
You can do your own report here:
WYRD is probably causing fundamental overload and its second harmonic falls right in the middle of CH 13.
WYRD FM 106.3 MHz x 2 = 212.6 MHz
CH 13, 210 to 216 MHz
You will need an FM filter or two in series, and you must ground the coax with a grounding block connected to the house electrical system ground to reduce interference.
FM filter, use one or two in series:
A HLSJ, HI & LINE ports, can also be used as an FM filter:
Did some aiming and got way more channels than with the indoor antenna but 13 is still useless. It does pick up channel 7 perfectly which is weird since it is also VHF and I found out the antenna I tried is UHF.
Channel 7 has 25.7 kW ERP at your location, but channel 13 has only 7 kW ERP.
http://www.tvfool.com/?option=com_wr...dALLTV%26n%3d6
http://www.tvfool.com/?option=com_wr...ALLTV%26n%3d14
