Trying to find something that I can mount on current pole.
If that is a requirement, then you'd better go and measure the pole to see what its outer diameter is. Otherwise you're going to be in for an unpleasant surprise if you buy an antenna with a clamp that is too small for the mast.
I suspect that the problem with WLOS is related to local interference. With a calculated margin of almost 40 dB, it should have been easily received by a DB2 .
