Old 22-Feb-2017, 12:29 PM   #6
Jake V
I'd find a way to insert the correct power supply for your amplifier just for a test. Then run a cable from the output of the amplifier directly to a television. If it works with the original power supply and won't fit where you want it you can always replace it with a amplifer with a remote power supply.
You can also easily check if your Tivo has issues by connecting the antenna directly to your television and scanning for channels a few times.
