Old 20-Feb-2017, 3:17 PM   #11
rickbb
There is another post here about using 2 antennas to redirect the signal from a high spot down to a house mounted antenna. I wonder if that could be used to eliminate the 200'+ runs for these kinds of location installs? You wouldn't have any coax to the tree or pre amp at all.
The setup uses one antenna aimed at the tower(s) to "catch" the signals, a short piece of coax to another antenna aimed at the house to "re-broadcast" the signal, and a 3rd antenna to receive and send to the TV(s).
