I was up on the roof today and I set the compass needle on north with the zero at the the north needle. Then aimed the antenna at 310 the best I could by eye. It was a little off before but turning the antenna a little to the right did not produce any difference in reception. I use a splitter after the 3410 for two tv's and one into my receiver for FM radio reception. This is the same set up I've been using for five years. Is the antenna direct juice a better amp than the cm 3410? I will look for some reviews about it online. Thank you.
