I aimed the HD7694P at 310 degrees and have the CM3410 installed before the cable goes into the TV. This set up has worked great for five years and now channel 33 is gone in the last month. Just curious why it quite working now. There are trees but they haven't affected it before and right now there are no leaves so it seems strange that would be a factor this time of year. Thank you for replying to my thread. If there is an antenna that may work better, what would you recommend?
