Old 14-Feb-2017, 2:38 PM   #5
Jake V
I agree with ADTEch.
Verdigris has the possibility of getting KCPQ (Fox) on Real Channel 13 (160 degrees). I've had good luck with the DB-4e picking up VHF-HI channels, so he might not require a VHF antenna to receive it. [He does not need to worry about CHAN (GTN) on VHF-LO 3 since it is also broadcast on UHF 22.]
Should he need a VHF-HI antenna I'd recommend the Stellar Labs VHF-HI (either the 30-2476 or the 30-2475) or the Antennas Direct ClearStream 5 (smaller, but much more expensive).
But, of course, Verdigris already has an antenna and he says is is aimed northeast. We need to know what brand / model it is. But I'd first recommend he aim it at 150-160 degrees (using a compass) and do a few re-scans to see what he gets.
Receiving PBS on real channel 9 is not realistic. But with the recommendations above you should receive K24IC (which is KBTC) on real channel 24 at 156 degrees.
