Old 14-Feb-2017, 1:23 PM   #4
Originally Posted by Jake V View Post
If this were me and I was just starting I'd probably try an Antennas Direct DB-4e with its reflector removed (to make it bi-directional) aimed at about 150 to 160 degrees.
That's certainly a great idea, it just requires a drill. The DB2e would be a great alternative with the same proviso and it's more economical and more compact.
A C2 or C4 is even easier, just don't install the separate reflector grids. Both are available (-V version) at Canadian Best Buy retail stores if waiting is an issue. The VHF element is unnecessary in Vancouver unless you wanted to use it for a modest FM antenna.
