In southern CT, WFSB and WCBS often interfere with each other as they are on the same operating channel. Care must be taken to reject WFSB if reception from NYC is your goal. Otherwise you'd have to fall back to WCBS's channel 22 translator out on Long Island, another challenge if it must be pulled off as it would require a separate antenna and a specialty combiner for best results.
The feasibility of an attic install is going to depend on the truss layout in your attic, your attic's orientation relative to required antenna placement for the antenna(s) selected, and your immediate surroundings in the direction of the signal path(s).
