Old 12-Feb-2017, 1:52 PM   #12
Would I be better off mounting this in the attic (near antenna) or down near the TV?
You would be better off returning it and getting your money back.
More gain almost never results in better reception, it doesn't work that way except when the additional gain is actually needed to overcome extensive downstream cabling and distribution losses. Usually, more gain simply results in more problems due to signal overloading in either the amplifier or in the attached tuners.
