Old 8-Feb-2017, 1:12 AM   #6
done w/cable
Thank You
WKRC is calculated to be LOS at >33 dB NM on VHF 12. At approximately unity gain for a simple dipole, that's more than 33 dB more power (before impairments and distribution losses) than the tuner requires for reception. That's approximately 20,000 times (in linear units) the needed value.
Thanks for the technical info, you lost me a little bit here. I know 0 dB NM or just above is minimum for reception if I remember correctly. I'm curious to know the formula used for figuring the 20,000 times needed value and what is (in linear units)? Thanks again.
done w/cable is offline   Reply With Quote
