Old 8-Feb-2017, 1:05 AM   #5
done w/cable
Thank you for the info.
Welcome, done w/cable:
I suggest the Winegard HD7694P aimed at 285 degrees magnetic. You should not need a preamp.
The Antennas Direct C2V should also work; its VHF dipole has less gain for VHF-High real channel 12, but it is less noticeable if eye appeal is important.
Since you are a ham, you might be interested in this:
http://www.reeve.com/Documents/Artic...ents_Reeve.pdf
73,
rabbit
I'm not a ham yet but hopefully soon, the antenna info is much appreciated I'll probably grab one off of amazon or somewhere here soon. The grounding info is beyond appreciative. I'll report back when I get everything up and running. Thanks again!
done w/cable is offline   Reply With Quote
