Originally Posted by seashipsink
channel 22.1 (CW) hasn't been giving a good signal lately. Looking at the TVFool report it seems I should be able to get that channel as well as all the others. Any suggestions?
Have you tried adjusting the dial on the base of your antenna? These dials on rabbit-ear + loop antennas are usually there to manually "tune" the loop portion of the antenna (the part that deals with UHF channels). According to the product description for your antenna, this 6-position switch should allow you to adjust the antenna slightly.
If you look at the example gain chart for a loop antenna below, each position of the dial on your antenna should cause the peak of the curve to move to a different channel. If you can find a position that optimizes the gain on channel 36, you might be able to stabilize KSKN (just try all 6 positions until you find the one or two positions that work best).
Typical gain for a generic loop antenna
That is what I had feared...do you know of anywhere I can find further information on this or if there is somewhere I can report these changes to get the software updated?
From what I've read, some of the database files can be edited by hand, but I've never tried this myself, so I can't offer very much guidance in the matter. I found this article on Microsoft's web site that might be of use (it's an older article, circa 2004):
http://www.microsoft.com/windowsxp/u...e_dec2004.mspx
If you're using a newer version of MCE (like Windows 7 era), then things seem to have changed a bit.
