Old 7-Feb-2017, 2:27 AM   #10
The main stations I want are WGBY real 22, WGGB real 40, and WWLP real 11.
Then you don't need a big wide antenna for VHF-Low like the 8200, but you do need the gain on UHF and VHF-High like the 7698.
Your signals are weak, 2Edge signals (terrain in the path), and you have trees. Putting up the 7698 is justified, and a preamp will be needed. You might get away with the smaller HD7694P, but I'm not sure it has enough gain.
No rotator needed; all three are about in the same direction.
WYCX is Retro TV
http://www.rabbitears.info/market.ph...&callsign=wycx
