Thx so much. I was looking @ the Virtual channel numbers from the Channel Master 7000. Looks like I am not picking up KSBW (NBC) either.
Pretty much all the houses on this street have stucco exterior walls. This explains the confusion I had--as I looked @ the TVFool report and the really poor signal I saw inside.
I wonder if any antenna similar to ANT-751/HBU22 you can recommend that can also pick up FM signals (or should all VHF antennas pick up FM signals?).
Thanks.
Add:
OK, I now see FM is 87.5–108 MHz: Band II Radio, so it is in the low-VHF... (correct me if I'm wrong).
