Old 5-Feb-2017, 2:44 AM   #4
too soon to tell
they are working on it
http://www.avsforum.com/forum/25-hdt...l#post46417657
Originally Posted by holl_ands View Post
Bear in mind that HVEC Codec is up to FOUR TIMES more Efficient than current MPEG2 Codec...hence a single ATSC 3.0 Transmitter could EASILY Broadcast ABC, CBS, NBC, FOX and FOUR MORE HD Channels at the SAME Time....as long as they remained in their current 1080i or 720p format.....OR 3-4+ Networks when the major Networks eventually upgrade to "4K" UDTV resolution....which is probably still 2-4 years away...
http://www.avsforum.com/forum/25-hdt...l#post50430705
ATSC 3.0's New HVEC Encoder is 3-4 times more Efficient than ATSC 1.0's MPEG2. Hence a 19.8 Mbps Data Stream could carry 3-4 times as many HD and SD programs with the SAME PQ (although ATSC 3.0 is capable of slightly higher Data Rate, let's assume the excess was allocated to OTHER Data Streams).
