Old 2-Feb-2017, 5:42 PM   #9
mikebuild
Thanks R73 ... those do look expensive.
So, in theory, I could walk my site with any antenna, connected to a tv with a signal meter, and locate the best reception spot? Yea? Na?
Another observation of the 7968 ... wind is not its freind
So obviously every tree between here and there is going to become more of a problem with reception, but how much of an issue will antenna vibration/movement be? In the wind, I can see the antenna wiggle a bit (not 100% secured yet) ... is that a big factor or not? The antenna does not rotate per sey, just a little rocking motion.
Thanks again.
mikebuild is offline   Reply With Quote
