Old 29-Jan-2011, 4:23 AM   #11
mtownsend
Originally Posted by rohit View Post
i really dont want to add an antenna just to pick up 1 channel (sorry ModernFamily on ABC)
Perfectly understandable.
From http://www.hdtvprimer.com/ANTENNAS/comparing.html it appears CM4228 may have much better VHF reception at the cost of increased size/cost.
Yes, it does. Note the long, continuous rods used in their reflector. It's *ok* for situations with really strong VHF signals, but it's still not as good as even the most basic VHF Yagi antennas.
Although instead of swapping out a DB4 to put in a CM4228, I'd opt for simply adding a YA-6713 to the DB4. The two antenna setup is a better all-around solution for your situation if you're going to go through the trouble of spending some money and reconfiguring your antennas.
