Old 1-Feb-2017, 4:54 PM   #35
dustyz
Two things...
Antennas Direct Tech support is awesome, and have been extremely patient and helpful via email. ADTech helped me learn, research, identify, and fix our channel loss issue.
It ended up being the preamp. I think the 7777 is amplifying, but at a much lower level than it should be. The loss in the coax was negligible. I still need to run some tests to verify the preamp is getting the correct voltage from the injector & not just overpowering the tuner. To be continued...
dustyz is offline   Reply With Quote
