Old 28-Jan-2017, 2:07 AM   #3
Putting an antenna in basement where the only signal path is through or around a larger home is usually two strikes against you. All you can do is take your best swing.
All of your Boston stations are UHF, you are unlikely to pick up any of the VHF stations from Providence with your given constraints.
